BT.com
Wishlist
Corsair 8GB (2 x 4GB) Vengeance Pro Red DDR3 1600MHz CL9
Delivery
Standard 3-5 working days
Corsair Vengeance Pro Series memory modules are designed for overclocking on the latest 3rd and 4th generation Intel® Core™ platforms, with eight-layer PCBs and ICs specially selected for performance potential. The aluminum heat spreaders provide superior temperature management and have the aggressive look you want in your gaming rig. XMP 1.3 profiles allow for automatic, reliable overclocking.
They're available in multiple colours to let you match your Vengeance Pro memory to your system's color scheme. As a bonus, they're priced to deliver class-leading value, so you'll have more room left in your system build budget.
Corsair Vengeance Pro Series - DDR3 - 8 GB: 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL9 (9-9-9-24)
Aluminium heatsink, dual channel, Vengeance heatspreader, Intel Extreme Memory Profiles (XMP 1.3), unbuffered
Voltage
1.5 V
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 (9-9-9-24)
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
Scroll to top
