Click to visit BT.com
BT.com
Wishlist
Corsair 8GB (2 x 4GB) Value DDR3 1600MHz 240-pin DIMM CL11
Quicklinx: 8LT6WS00
Mfr#: CMV8GX3M2A1600C11
The Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop and laptop systems.
Corsair Value Select - DDR3 - 8 GB : 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL11 ( 11-11-11-30 )
Dual channel , unbuffered
Voltage
1.5 V
8 GB : 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
