BT.com
Wishlist
Corsair 8GB (2 x 4GB) DDR3 1866Mhz CL10 Vengeance SODIMM Performance Notebook Memory Module
Delivery
Standard Due date unavailable
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
Corsair Vengeance - DDR3L - 8 GB: 2 x 4 GB - SO-DIMM 204-pin
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz (PC3-15000)
Latency Timings
CL10 (9-9-9-24)
Unbuffered
Voltage
1.35 V
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL10 (9-9-9-24)
Non-ECC
Unbuffered
Voltage
1.35 V
Scroll to top
