BT.com
Wishlist
Corsair 8GB (1x8GB) DDR3 1600MHz PC3-12800 204-pin SO-DIMM
Delivery
Standard Due date unavailable
The Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop and laptop systems.
CORSAIR Value Select - DDR3L - 8 GB - SO-DIMM 204-pin - unbuffered
RAM memory
8 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11 (11-11-11-28)
Low Voltage, unbuffered
Voltage
1.35 V
8 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL11 (11-11-11-28)
Non-ECC
Voltage
1.35 V
Scroll to top
