Click to visit BT.com
BT.com
Wishlist
Corsair 8GB (1x8GB) DDR3 1600Mhz CL10 Vengeance SODIMM Performance Notebook Memory Module
Quicklinx: 82MVWS00
Mfr#: CMSX8GX3M1A1600C10
Type: DDR3 SDRAM
Capacity: 8GB
Connection: SO-DIMM 204-pin
Speed: 1600MHz
Data Integrity: Non-ECC
Standard delivery Delivered within 3-5 working days
1 in stock
£31.45
CORSAIR high performance Vengeance SODIMM memory module, 8GB (1x8GB) 1600MHz 10-10-10-27, 1.5V, allows you to automatically boost performance of your without bios reconfiguration. Slim and attractive design to ensure physical compatibility with all 2nd Generation Intel Core™ i5 and i7 notebooks. Each module is built using carefully selected DRAM to allow excellent stability and is backed by Corsair's limited lifetime warranty.
Key Features
  • 8GB (1x8GB) DDR3 SODIMM for 2nd Generation Intel Core™ i5 and i7 notebooks.
  • 1600MHz
  • 10-10-10-27 latency
  • 1.5V
  • Auto-overclocking (no bios configuration required)
  • Limited Lifetime Warranty
  • Density: 8GB (1x8GB Module)
  • Speed: 1600MHz
  • Timing: 10-10-10-27
  • Type: DDR3
  • Format: SODIMM
  • Pin Out: 204 Pin
  • Voltage: 1.5V
  • Note: if two modules are used both should be the same speed and timings
Corsair Vengeance - DDR3 - 8 GB - SO-DIMM 204-pin
RAM memory
8 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL10 ( 10-10-10-27 )
Unbuffered
Voltage
1.5 V
8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
Non-ECC
Unbuffered
Voltage
1.5 V
Compatible Slots
1 x memory - SO-DIMM 204-pin
Corsair 8GB (1x8GB) DDR3 1600Mhz CL10 Vengeance SODIMM  Performance Notebook Memory Module Bundle deal on Corsair 8GB (1x8GB) DDR3 1600Mhz CL10 Vengeance SODIMM Performance Notebook Memory Module
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.62 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£50.98
saving £8.68
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£41.44
Type: DDR3 SDRAM
Capacity: 8GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL10
Standard: PC3-12800
Brand: Corsair
Price Range Inc VAT: 0 - 50
