BT.com
Wishlist
Corsair 8GB (1x8GB) DDR3 1333Mhz CL9 Value Select Desktop Memory Module
Delivery
Standard Due date unavailable
The Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop and laptop systems.
Corsair Value Select - DDR3 - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9 (9-9-9-24)
Unbuffered
Voltage
1.5 V
8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 (9-9-9-24)
Non-ECC
Unbuffered
Voltage
1.5 V
Compatible Slots
1 x memory - DIMM 240-pin
Scroll to top
