BT.com
Wishlist
Corsair 860W AX860i 80PLUS Platinum High Performance Digital PSU
Corsair 860W AX860i 80PLUS Platinum...
£205.16
17 in stock
£205.16
Add to wishlist
Delivery
Standard 1-3 working days
Compatible with 4th generation Intel® Core™ series processors
The world's first enthusiast-grade digital ATX power supplies.
Digitally Controlled Power
The fully modular Corsair AX860i uses a Digital Signal Processor (DSP) for tighter voltage regulation, which improves overall system stability, and increases performance to 80 PLUS® Platinum levels. Built-in Corsair Link™ gives you unprecedented monitoring and control.
Quiet, Efficient Operation
Upgrading to digital provides increased efficiency. The AX860i is certified 80 PLUS® Platinum, which results in lower heat generation and a quieter fan profile. The AX860i is so efficient that the 120mm fan doesn't even spin at low loads for completely noiseless power delivery.
CORSAIR LINK™
The built-in Corsair Link™ functionality allows you to know how well your AX860i is working at any given moment and lets you quickly tweak its performance. Server-inspired diagnostic tools monitor real-time efficiency, power usage, configurable over-current protection points and fan profiles.
Product Features
  • The latest ATX12V v2.31 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems.
  • Silent at low to moderate load due to high efficiency and zero RPM fanless mode. Ultra quiet at high loads with 120mm dual-ball bearing fan.
  • 80PLUS Platinum certified, delivering over 92% energy efficiency at real world load conditions.
  • Active Power Factor Correction (PFC) with PF value of 0.99.
  • Universal AC input from 90~264V. No more hassle of flipping that tiny red switch to select the voltage input!
  • A dedicated single +12V rail offers maximum compatibility with the latest components.
  • Over-voltage and over-current protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components.
  • High-quality Japanese capacitors provide uncompromised performance and reliability.
  • The completely modular cable system allows you to use only the cables you need. Power supply upgrade and replacement is easy, as the cables only need to be disconnected at the power supply.
  • Low-profile, flat cable design reduces air friction and helps maximize airflow through your computer's chassis.
  • A Seven year warranty and lifetime access to Corsair's legendary technical support and customer service.
  • Safety Approvals: cTUVs, TUV, CB, CE, FCC, CCC, RCM, GOST-R, KC, IRAM, BSMI.
Corsair AX860i - power supply - 860 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31/ EPS12V 2.92
80 PLUS Certification
80 PLUS Platinum
3.29 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
860 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 8 x 4 PIN internal power , 12 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector
Cooling System
140 mm fan
Cable ties, mounting kit, cable bag
15 cm x 16 cm x 8.6 cm
10 years warranty
United Kingdom
Input Voltage
AC 100-240 V
Input Voltage Range
AC 90 - 264 V
Frequency Required
50/60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
860 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 71.6 A , -12V - 0.8 A , +5VSB - 3 A
80 PLUS Platinum
Power cable kit
MTBF
100,000 hours
Cooling System
140 mm fan
Corsair Link, over current protection, over voltage protection, undervoltage protection, short-circuit protection, single 12V rail, dual ball bearing cooling fan
FCC Class B certified, TUV, C-Tick, CB, CCC, cTUVus
Limited warranty - 10 years
15 cm
16 cm
8.6 cm
3.29 kg
Shipping Width
39.1 cm
Shipping Depth
22.5 cm
Shipping Height
15.1 cm
Shipping Weight
4 kg
Corsair 860W AX860i 80PLUS Platinum High Performance...
£205.16
Save on this ideal PC Build kit!
Save £8.29
£224.33
Resources
The following resources are available for the Corsair 860W AX860i 80PLUS Platinum High Performance Digital PSU
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Corsair 860W AX860i
Reviewed by Wayne on 14/01/2013
Great product this is my second Corsair power supply they are awesome, plus on the brite side u know your gaming rig is safe due to spikes or other problem due to cheap power supply's. The cables are quite easy to hook up the software's easy to download and use, the only thing is Im not sure if its due to my mother board or its CorsairLink 2 isn't that great or my mother boards not compatible. The power supply is basically silent very quiet and the fan only turns itself on once in a while even after being on for days on end. Comes with a great case and a nice power pouch bag, The cables are well built and are long enough for most cases im not sure about all the gamer cases. Only thing that would be nice would be clearer marking on the cables. And u cant be a 7 years warrant, customer support is excellent too.
Scroll to top
