Click to visit BT.com
BT.com
Wishlist
Corsair 860W AX860 80PLUS Platinum High Performance PSU
Quicklinx: 8D4VWS00
Mfr#: CP-9020044-UK
Power Rating: 860Watt
Standard delivery Delivered within 3-5 working days
1 in stock
£171.68
Compatible with 4th generation Intel® Core™ series processors
A new more efficient version of the awarding winning AX Series power supplies
Platinum Efficiency and Silent Fanless Mode
The Corsair AX860 power supply runs quieter, generates minimal excess heat and it's earned the 80 Plus® Platinum seal of approval, your guarantee that you're making the right choice for smart, efficient power delivery. Because the AX860 is so efficient it operates without the fan even spinning at low and moderate loads.
A Fully Modular Cabling System
All cables detach from the power supply. During installation, this gives you the flexibility of using only the cables you need for a clean system build with optimal airflow.
Built with the Best
Built with High-quality 105C capacitors and upgraded components the AX860 is rated to run at 50°C and provide rock solid power throughout its seven year warranty.
Product Features
  • The latest ATX12V v2.31 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems.
  • Silent at low to moderate load due to high efficiency and zero RPM fanless mode. Ultra quiet at high loads with 120mm dual-ball bearing fan.
  • 80PLUS Platinum certified, delivering over 92% energy efficiency at real world load conditions.
  • Active Power Factor Correction (PFC) with PF value of 0.99.
  • Universal AC input from 90~264V. No more hassle of flipping that tiny red switch to select the voltage input!
  • A dedicated single +12V rail offers maximum compatibility with the latest components.
  • Over-voltage and over-current protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components.
  • High-quality Japanese capacitors provide uncompromised performance and reliability.
  • The completely modular cable system allows you to use only the cables you need. Power supply upgrade and replacement is easy, as the cables only need to be disconnected at the power supply.
  • Low-profile, flat cable design reduces air friction and helps maximize airflow through your computer's chassis.
  • A Seven year warranty and lifetime access to Corsair's legendary technical support and customer service.
  • Safety Approvals: cTUVs, TUV, CB, CE, FCC, CCC, RCM, GOST-R, KC, IRAM, BSMI.
Corsair AX860 - power supply - 860 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31/ EPS12V 2.92
80 PLUS Certification
80 PLUS Platinum
3.29 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
860 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 8 x 4 PIN internal power , 12 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector
Cooling System
140 mm fan
Cable ties, cable bag, mounting kit
15 cm x 16 cm x 8.6 cm
7 years warranty
United Kingdom
Input Voltage
AC 100-240 V
Input Voltage Range
AC 90 - 264 V
Frequency Required
50/60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
860 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 71.6 A , -12V - 0.8 A , +5VSB - 3 A
80 PLUS Platinum
1 x power cable kit
MTBF
100,000 hours
Cooling System
140 mm fan
Over current protection, over voltage protection, undervoltage protection, short-circuit protection, single 12V rail, dual ball bearing cooling fan
FCC Class B certified, TUV, C-Tick, BSMI, CB, CCC, IRAM, GOST-R, cTUVus, KC
7 years warranty
Service & Support Details
Limited warranty - 7 years
15 cm
16 cm
8.6 cm
3.29 kg
Shipping Width
39.1 cm
Shipping Depth
22.5 cm
Shipping Height
15.1 cm
Shipping Weight
4 kg
Corsair 860W AX860 80PLUS Platinum High Performance PSU Bundle deal on Corsair 860W AX860 80PLUS Platinum High Performance PSU
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£191.21
saving £8.26
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£175.77
saving £1.39
Resources
The following resources are available for the Corsair 860W AX860 80PLUS Platinum High Performance PSU
Brand: Corsair
Price Range Inc VAT: 150 - 300
