BT.com
Wishlist
Corsair 750W CX Builder Series 80PLUS Bronze PSU
Delivery
Standard Due date unavailable
The CX750 is 80 PLUS Bronze certified for excellent efficiency, and like all the CX series PSUs, is an ideal solution for those who want a no-compatibility. With a temperature controlled fan for low noise levels, long cables with tons of connectors for flexibility, and fully sleeved cables, the CX750 is a great choice at a great price.
CORSAIR CX750 - power supply - 750 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31/ EPS12V 2.91
80 PLUS Certification
80 PLUS Bronze
3.27 kg
United Kingdom
Input Voltage
AC 90-264 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V , 4 x 8 pin PCI Express power with detachable 2 pin section , 1 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
15 cm x 16 cm x 8.6 cm
3 years warranty
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 90-264 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 62 A , -12V - 0.8 A , +5VSB - 3 A
80 PLUS Bronze
MTBF
100,000 hours
Sleeved cables, over current protection, over voltage protection, undervoltage protection, short-circuit protection, single 12V rail, non-modular
Limited warranty - 3 years
15 cm
16 cm
8.6 cm
3.27 kg
Shipping Width
29 cm
Shipping Depth
21.6 cm
Shipping Height
13 cm
Shipping Weight
3.53 kg
Resources
The following resources are available for the Corsair 750W CX Builder Series 80PLUS Bronze PSU
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Powerful, Quite and a lot of cables
Reviewed by Joe on 13/02/2014
All the cables you will need, 4 pci-e, molex and a few floppy drive power cables, pair this with a corsair case (c70) an it's great. Quite and constant power flow.
5* quiet PSU and more than enough connections
Reviewed by James on 17/02/2014
Ive had a few cheaper PSU's purchased from other suppliers but after spending a fair amount on a custom build I decided it was time to purchase a good quality PSU and a named brand.
after looking at a few brands and models I choose the Corsair CX750. this is possibly a bit overkill for my Pc at the moment but it gives me room for upgrades.
Im more than happy on how its running and is silent compared to my old PSU.
overall theres plenty of connections for all your needs and has the power to back the connections up.
Scroll to top
