Click to visit BT.com
BT.com
Wishlist
Corsair 750 Watt Builder Series CX 750 Modular Power Supply
1.0*
Quicklinx: 8GFWWS00
Mfr#: CP-9020061-UK
Power Rating: 750Watt
Standard delivery Delivered within 3-5 working days
More than 50 in stock
£83.20
CX Series modular power supply units are an excellent choice for basic system builds and desktop PC computer upgrades, offering high reliability, low noise, and easy installation. The flexible modular cabling system lets you use only the cables you need, and 80 PLUS Bronze certified efficiency means less excess heat, lower noise, and lower power bills. The large-diameter, thermally controlled fan makes the CX Series modular quieter at idle, and the large diameter reduces noise even when you're pushing your system hard. And, the matte finish, sleeved cables and connectors help give your system a restrained, high-tech look.
Corsair CX750M - power supply - 750 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ EPS12V 2.91
80 PLUS Certification
80 PLUS Bronze
3.27 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 8 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 2 x 4 PIN mini-power connector
15 cm x 16 cm x 8.6 cm
3 years warranty
Matte black
United Kingdom
Input Voltage
AC 100-240 V
Input Voltage Range
AC 90 - 264 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 62 A , -12V - 0.8 A , +5VSB - 3 A
Efficiency
85%
80 PLUS Bronze
MTBF
100,000 hours
Sleeved cables , over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail, temperature controlled fan
Energy-Related Products (ErP) Lot 6
3 years warranty
Service & Support Details
Limited warranty - 3 years
15 cm
16 cm
8.6 cm
3.27 kg
Shipping Width
29 cm
Shipping Depth
21.6 cm
Shipping Height
13 cm
Shipping Weight
3.53 kg
Corsair 750 Watt Builder Series CX 750 Modular Power Supply Bundle deal on Corsair 750 Watt Builder Series CX 750 Modular Power Supply
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£102.73
saving £8.26
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£93.19
saving £4.99
Customer reviews
Write a review for the Corsair 750 Watt Builder Series CX 750 Modular Power Supply here!
Great for 12 1/2 months
Reviewed by Anonymous Review Posted 17/02/2015
Worked fine for 12 months and 14 days , then it popped it's mains fuse . PSU dead. the 3 year warranty is fine if you live in Holland as you have to pay the return postage . From here in the UK that is almost the cost of the PSU. Thus the warranty is effectively worthless.
Voting with my wallet and never buying Corsair again.
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Brand: Corsair
Price Range Inc VAT: 50 - 100
