Click to visit BT.com
BT.com
Wishlist
Corsair 700W Gaming Series GS700 2013 Edition 80+ Bronze, ATX, PS/2 PSU
Quicklinx: 8H0HWS00
Mfr#: CP-9020064-UK
Compatible with 4th generation Intel® Core™ series processors
The all-new, 80 PLUS® Bronze certified GS power supplies are quieter with fan-less operation at low loads, and look good with their colour-switchable LED fans (Blue LED only on 600W version ). The GS family of power supplies is designed to produce reliable, constant power to your high-current devices, and is an excellent choice for overclocked CPUs or high-end GPU systems. Each GS power supply has long cables for today's bottom-mount PSU cases and multiple connectors to ensure compatibility with a wide variety of devices.
  • Fan-less mode at low loads for quiet operation, with an ultra-quiet 140mm double ball-bearing fan that delivers excellent airflow when needed.
  • Colour adjustable LED fan can switch between red, blue, white, and off settings by pressing the button on the back. (600W model - blue or off mode only)
  • Up to 85% energy efficiency means less heat generation and lower energy bills.
  • 0.99 Active Power Factor Correction provides clean and reliable power.
  • Universal AC input from 100~240V.
  • A dedicated single +12V rail offers maximum compatibility with the latest components.
  • Over-voltage and over-power protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components.
  • Extra long fully-sleeved cables support full tower chassis.
  • It supports the latest ATX12V v2.3 standard and is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems.
  • A three year warranty and lifetime access to Corsair's legendary technical support and customer service.
Corsair GS700 - 2013 Edition - power supply - 700 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ EPS12V
80 PLUS Certification
80 PLUS Bronze
3.27 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
700 Watt
Output Connector(s)
1 x power 24 pin ATX , 1 x power 8 pin EPS12V , 2 x 6 pin PCI Express power , 8 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 2 x 4 PIN mini-power connector
Cooling System
140 mm fan
Cable ties, mounting kit
15 cm x 16 cm x 8.6 cm
3 years warranty
ATX12V 2.3/ EPS12V
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
700 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 49 A , -12V - 0.8 A , +5VSB - 3 A
Efficiency
85%
80 PLUS Bronze
MTBF
100,000 hours
Cooling System
140 mm fan
Sleeved cables , over current protection, over voltage protection, undervoltage protection, short-circuit protection, single 12V rail, dual ball bearing cooling fan, blue LED lighting, white LED lighting, red LED lighting, LED lighting on/off switch, Zero RPM fan mode
FCC Class B certified, TUV, C-Tick, CB, CCC, cTUVus
3 years warranty
Service & Support Details
Limited warranty - 3 years
15 cm
16 cm
8.6 cm
3.27 kg
Shipping Width
21.6 cm
Shipping Depth
29 cm
Shipping Height
13 cm
Shipping Weight
3.53 kg
Resources
The following resources are available for the Corsair 700W Gaming Series GS700 2013 Edition 80+ Bronze, ATX, PS/2 PSU
