BT.com
Wishlist
Corsair 600W Builder Series CX Series CX 80+ Bronze ATX Power Supply
Corsair 600W Builder Series CX...
£62.20
19 in stock
£62.20
Add to wishlist
Delivery
Standard 3-5 working days
The CX Series is an ideal solution for those who want a no-nonsense, reliable power supply that's designed for maximum compatibility. Unlike other PSUs in its price range, the CX series is rated for continuous power output for maximum compatibility and reliability, and it carries the 80 Plus® Bronze certification for efficiency. A great budget choice.
  • Corsair engineering and quality control
  • Plentiful connectors and long cables
  • 80 PLUS® Bronze Certified efficiency
  • Large diameter, thermally controller fan
  • Black housing and all-black sleeved cables and connectors
  • 3 Years Manufacturers Warranty
  • Model: CX600
  • AC Input: 100-240V
  • Input Current: 10-5A
  • Frequency: 47~63Hz
  • Max Load Max Output: +3.3V 120W 25A, +5V 25A 130W, +12V 46A 552W, -12V 9.6W 0.8A, +5Vsb 15W 3A
  • Total Power: 600W
  • Warranty: 3 Years Manufacturers Warranty
Corsair CX600 - power supply - 600 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ EPS12V
80 PLUS Certification
80 PLUS Bronze
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
600 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
3 years warranty
ATX12V 2.3/ EPS12V
United Kingdom
Input Voltage
AC 100-240 V
Input Voltage Range
AC 190 - 264 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
600 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 46 A , -12V - 0.8 A , +5VSB - 3 A
80 PLUS Bronze
MTBF
100,000 hours
Cooling System
120 mm fan
Over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail
FCC Class B certified, UL, TUV, C-Tick, cUL, CB, CCC, Energy-Related Products (ErP) Lot 6
3 years warranty
Service & Support Details
Limited warranty - 3 years
15 cm
14 cm
8.6 cm
Shipping Width
19.05 cm
Shipping Depth
26.67 cm
Shipping Height
9.855 cm
Shipping Weight
2.32 kg
Corsair 600W Builder Series CX Series CX 80+ Bronze ATX...
£62.20
Save on this ideal PC Build kit!
Save £16.94
£87.58
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great PSU
Reviewed by Anonymous on 23/09/2013
Great PSU, looks cool and has nice bottom mounted fan. The cable 'sheathing?' is kind of see-through so you can see the cable colors underneath unfortunately.
Plenty of cables for pretty much everything and easy to install.
It's only £6 less than it's modular counterpart though and the cables that you don't use are kind of a nuisance.
5* Excellent And Cheap!!!
Reviewed by Mark on 09/02/2014
I paid £70 for this power supply down my local high street simply because I did not have the patience to wait for delivery. I have now purchased the next model up still for cheaper than I paid on the high street, so you are getting an excellent bargain to say the least. I brought one power supply that would not even work my graphics card and yet this made it a lot easier to get the graphics card up and running. This is one serious bad boy and I would recommended and use it without any hesitation. It really does have the power and cables that you need to have a decent system up and running quickly.
5* CORSAIR 600W psu
Reviewed by Kim Bowers on 06/02/2013
Oops go it wrong on my first review.Found the problem and it was not a PSU fault. Senior moment I think or check and recheck all the wires are on the motherboard. So I have now reviewed it with a better overall score
4* Great product
Reviewed by David on 25/08/2014
Great product. I was nervous about buying the wrong product and about whether I'd be competent to replace my original PSU. I hoped there might be an idiots' guide as to which leads plug in where. There wasn't, but by taking note of the leads I removed and their connectors, plus some Internet searching, I worked it out and it has solved the problems I was having with my Dell Studio XPS 435mt. All the additional connectors will satisfy those looking to add new hardware, but that's definitely beyond me. Great service from BT.com.
3* Corsair 600W CX
Reviewed by Robert Armstrong on 29/07/2014
Bought 2 of these units for new build computers. Easy to install, multiple connectors and very quiet in operation. However, one psu failed after 3 months - acrid fumes from unit, (possibly it's fan stopped working). With a shipping cost of £31 to return it to Corsair for assessment (which is what BT requires) it hardly seems worth the bother. Have bought another as replacement, so will see how that goes!
1* Corsair 600w PSU
Reviewed by Kim Bowers on 05/02/2013
After reading many reviews on lot of sites I decided I would go for this make of PSU.
Maybe I've been unlucky but I fitted the PSU to the case and components turned on the mains power and absolutely nothing happened DOE.So it's back to Dabbs for a refund (can't wait for 10 to 14 days for replacement). Back to reading more reviews? Also when I get the next PSU I will test it before fitting it in the case
Scroll to top
