BT.com
Wishlist
Corsair 550W CS550M CSM Semi-Modular 80+ GOLD Certified Power Supply
Delivery
Standard Due date unavailable
Corsair CS MODULAR Series power supplies are an excellent choice for mid-range system builds and most desktop PC computer upgrades. CS-M PSUs are semi-modular and feature 80 PLUS Gold rated efficiency that saves you money on your power bill while generating less heat than many other power supplies. The modular flat black cables allow users fast, neat builds. DC to DC technology ensures 100% compatibility with 4th Generation Intel Core processors.
  • The Perfect Choice For Your PC - CS MODULAR Series power supplies are a perfect choice for either new builds or PC desktop upgrades with high-efficiency and low noise.
  • 80 PLUS Gold-certified Efficiency - Highly efficient CS MODULAR Series power supplies produce less heat and have lower operating costs.
  • Flat black, Low-Profile Modular Cables - You can remove unneeded cables and leave them in the box for fast, easy, and great-looking builds.
  • Reliable, Continuous Power Delivery - CS MODULAR Series power ratings are continuous, not peak, for superior protection for your valuable PC.
  • Corsair uses high-quality internal components, and CS MODULAR Series power supplies are guaranteed to deliver clean, stable, continuous power.
Corsair CS Series CS550M - power supply - 550 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Gold
1.974 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
550 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 4 PIN internal power , 5 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector , 2 x 8 pin PCI Express power with detachable 2 pin section
15 cm x 14 cm x 8.6 cm
3 years warranty
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
550 Watt
Output Current
+3.3V - 25 A , +5V - 20 A , +12V - 43 A , -12V - 0.8 A , +5VSB - 3 A
Efficiency
92%
80 PLUS Gold
MTBF
150,000 hours
Sleeved cables, over voltage protection, overpower protection, temperature auto control, undervoltage protection, short-circuit protection, Multi-GPU Technologies Supported
UL, TUV, BSMI, cUL, CB, CCC, FCC, RoHS, WEEE, ICES, KC, EAC, RCM
Limited warranty - 3 years
15 cm
14 cm
8.6 cm
1.974 kg
Shipping Width
9.8 cm
Shipping Depth
26.8 cm
Shipping Height
19 cm
Shipping Weight
2.194 kg
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Efficient and quiet.
Reviewed by Steve on 07/07/2014
Slotted into the case perfectly. Easy plug in cables with ties so you don't have spaghetti cabling everywhere.
5* Excellent
Reviewed by Anonymous on 01/08/2015
An excellent PSU to buy if your looking to put together a computer with one GPU.
Scroll to top
