BT.com
Wishlist
Corsair 500W Builder Series CX 80+ Bronze ATX Power Supply
Corsair 500W Builder Series CX 80+...
£52.20
More than 50 in stock
£52.20
Add to wishlist
Delivery
Standard 3-5 working days
The CX Series is an ideal solution for those who want a no-nonsense, reliable power supply that's designed for maximum compatibility. Unlike other PSUs in its price range, the CX series is rated for continuous power output for maximum compatibility and reliability, and it carries the 80 Plus® Bronze certification for efficiency. A great budget choice.
  • Corsair engineering and quality control
  • Plentiful connectors and long cables
  • 80 PLUS® Bronze Certified efficiency
  • Large diameter, thermally controller fan
  • Black housing and all-black sleeved cables and connectors
  • 3 Years Manufacturers Warranty
  • Model: CX500
  • AC Input: 100-240V
  • Input Current: 10-5A
  • Frequency: 47~63Hz
  • Max Load Max Output: +3.3V 120W 25A, +5V 120W 20A, +12V 456W 38A, -12V 9.6W 0.8A, +5Vsb 15W 3A
  • Total Power: 500W
  • Warranty: 3 Years Manufacturers Warranty
Corsair CX500 - power supply - 500 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ PS/2
80 PLUS Certification
80 PLUS Bronze
United Kingdom
Input Voltage
AC 90-264 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
500 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 6 pin PCI Express power , 4 x 4 PIN internal power , 5 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
3 years warranty
ATX12V 2.3/ PS/2
United Kingdom
Input Voltage
AC 90-264 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
500 Watt
Output Current
+3.3V - 25 A , +5V - 20 A , +12V - 38 A , -12V - 0.8 A , +5VSB - 3 A
80 PLUS Bronze
MTBF
100,000 hours
Cooling System
120 mm fan
Over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail
FCC Class B certified, UL, TUV, C-Tick, cUL, CB, CCC, Energy-Related Products (ErP) Lot 6
3 years warranty
Service & Support Details
Limited warranty - 3 years
15 cm
14 cm
8.6 cm
Shipping Width
19.05 cm
Shipping Depth
26.67 cm
Shipping Height
9.855 cm
Shipping Weight
2.32 kg
Corsair 500W Builder Series CX 80+ Bronze ATX Power...
£52.20
Save on this ideal PC Build kit!
Save £10.63
£71.37
Scroll to top
