BT.com
Wishlist
Corsair 500 Watt CX500 V2 Builder Series 80 Plus Power Supply
Delivery
Standard Due date unavailable
The Builder Series CX500 V2 delivers the power needed for medium specification home or office PCs that do not have high numbers of components, while also offering high energy efficiency and low noise. The Corsair Builder Series PSUs are designed for worry-free compatibility for your home desktop PC system build or upgrade. With features usually reserved for premium power supplies, it's a great choice for systems where continuous and reliable power delivery and low noise are essential.
  • Ultra-quiet 120mm fan delivers excellent airflow at exceptionally low noise levels by varying fan speed in response to temperature
  • 80 PLUS certified to deliver at least 80% efficiency or higher at normal load conditions (20% to 100% load)
  • 0.99 Active Power Factor Correction provides clean and reliable power
  • Complies with ErP Lot 6 European Union standard for low standby power consumption
  • 3 Years Warranty
"* Voltage: +3.3V, +5V, +12V, -12V, +5Vsb - Max. Current: 25A, 20A, 34A, 0.8A, 3A - Max Combined Wattage: 130W, 408W, 9.6W, 15W, 500 Watts @ 30°C ambient temperature - Power: 500 Watts - 80 Plus: Certified - ATX Connector: 1 - EPS Connector: 1 - PCI-E Connector: 2 - 4 Pin Peripheral Connector: 4 - SATA Connector: 5 - Floppy Connector: 1 - MTBF: 100,000 hours - Warranty: 3 Years
Corsair Builder Series CX500 V2 - power supply - 500 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ EPS12V
80 PLUS Certification
80 PLUS
United Kingdom
Input Voltage
AC 90-264 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
500 Watt
Output connectors
1 x power 24 pin ATX , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 6 pin PCI Express power , 4 x 4 PIN internal power , 5 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
3 years warranty
ATX12V 2.3/ EPS12V
United Kingdom
Input Voltage
AC 90-264 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
500 Watt
Output Current
+3.3V - 25 A , +5V - 20 A , +12V - 34 A , -12V - 0.8 A , +5VSB - 3 A
80 PLUS
MTBF
100,000 hours
Cooling System
120 mm fan
Sleeved cables, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail
FCC Class B certified, UL, TUV, C-Tick, cUL, CB, CCC, Energy-Related Products (ErP) Lot 6
Limited warranty - 3 years
15 cm
14 cm
8.6 cm
Shipping Width
19.1 cm
Shipping Depth
26.7 cm
Shipping Height
9.9 cm
Shipping Weight
2.3 kg
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great PSU
Reviewed by Sean on 16/09/2011
A simply great PSU. Very useful if you have a DELL Inspiron 545 as it will replace the old poor 300Watt psu it comes with nicely. It also then means you can put in the more modern NVIDIA Fermi cards and more! I knocked a point off of ease of use because the cables are pretty long and encased in a mesh making them slightly difficult to manoeuvre but it does come with cable ties so this is not too bad! Its also very quiet and that cant be a bad thing! All in all I'd recommend this for those looking to upgrade.
5* Easy for a first time builder1
Reviewed by Joe on 06/10/2012
Great solid psu reliable and good brand. first time I've built a pc and there was no worrys at all , works fine with i5 2500k!
Scroll to top
