BT.com
Wishlist
Corsair 4GB (2x2GB) DDR2 800Mhz CL5 Value Select 240 Pin Desktop Memory Kit
Delivery
Standard Due date unavailable
The Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop and laptop systems.
CORSAIR Value Select - DDR2 - 4 GB: 2 x 2 GB - DIMM 240-pin - unbuffered
RAM memory
4 GB: 2 x 2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Latency Timings
CL5 (5-5-5-18)
Unbuffered
Voltage
1.8 V
4 GB: 2 x 2 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
800 MHz (PC2-6400)
Latency Timings
CL5 (5-5-5-18)
Non-ECC
Unbuffered
Voltage
1.8 V
Compatible Slots
2 x memory - DIMM 240-pin
Scroll to top
