Click to visit BT.com
BT.com
Wishlist
Corsair 4GB (1x4GB) DDR3 1600Mhz CL9 Vengeance Black Performance Desktop Memory Module
5.0*
Quicklinx: 79V5WS00
Mfr#: CMZ4GX3M1A1600C9
Type: DDR3 SDRAM
Capacity: 4GB
Connection: DIMM 240-pin
Speed: 1600MHz
CAS Latency: CL9
£32.66
Overclocking Memory from Corsair - the Leader in Performance Memory Solutions
CORSAIR high performance Vengeance memory module 4GB (1x4GB) 1600MHz 9-9-9-24, 1.5V for AMD and Intel platforms. Operates in single channel mode when installed individually. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
Key Features
  • 4GB (1x4GB) DDR3 for AMD and Intel Dual and Triple processors
  • Operates in Single Channel mode when installed individually
  • 1600MHz 9-9-9-24 latency
  • Vengeance heat spreader for styling and performance
  • Intel XMP (Extreme Memory Profile) Support
  • Limited Lifetime Warranty
  • Density: 4GB (1x4GB Module)
  • Speed: 1600MHz
  • Timing: 9-9-9-24
  • Type: DDR3
  • Format: DIMM
  • Pin Out: 240 Pin
  • Voltage: 1.5V
  • Great looking, great overclocking memory
    Corsair Vengeance DDR3 memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
  • Optimized for compatibility with the CPUs and motherboards
    Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages. Vengeance DDR3 memory is available in single modules, and two or three module kits, making it easy for you to match the DIMM population requirements of your motherboard.
  • Next-generation density for the ultimate power user
    Most Vengeance DIMMs are built with two gigabit RAM ICs. These extra-dense memory chips allow you to have 8GB of memory using only two DIMMs, or to populate your triple channel system with up to an insanely large 24GB of system memory for extreme multitasking performance.
Corsair Vengeance memory - 4 GB - DIMM 240-pin - DDR3
Storage Capacity
4 GB
DDR3 SDRAM
DIMM 240-pin
Memory Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL9
Intel Extreme Memory Profiles (XMP), Vengeance heatspreader
Storage Capacity
4 GB
DRAM
DDR3 SDRAM
DIMM 240-pin
Memory Speed
Latency Timings
CL9
RAM Features
Corsair 4GB (1x4GB) DDR3 1600Mhz CL9 Vengeance Black Performance Desktop Memory Module Bundle deal on Corsair 4GB (1x4GB) DDR3 1600Mhz CL9 Vengeance Black Performance Desktop Memory Module
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.62 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£52.19
saving £8.68
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£42.65
Resources
The following resources are available for the Corsair 4GB (1x4GB) DDR3 1600Mhz CL9 Vengeance Black Performance Desktop Memory Module
Customer reviews
Write a review for the Corsair 4GB (1x4GB) DDR3 1600Mhz CL9 Vengeance Black Performance Desktop Memory Module here!
Awesome memory
Reviewed by Phil Shaw. Review Posted 16/03/2012
Awesome memory
I installed 3 sticks into my triple channel i7 motherboard and set X.M.P. profile in the BIOS so the memory would run at the correct timing (9-9-9-24 1600Mhz).
It worked out cheaper to buy 3 4GB sticks for £60 than to buy the 12GB triple channel kit at £80, saved myself £20
I’m very happy with the quality and performance of this memory, it’s much better than the OCZ Gold Edition Memory I had in my system before.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
does what it says on the tin!
Reviewed by peter. Review Posted 21/12/2011
certainly nips along but for a lot less money.
no complaints at all
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Type: DDR3 SDRAM
Capacity: 4GB
Speed: 1600MHz
CAS Latency: CL9
Standard: PC3-12800
Brand: Corsair
Price Range Inc VAT: 0 - 50
