BT.com
Wishlist
Corsair 4GB (1x4GB) 1600MHz CL11 DDR3L Memory
Delivery
Standard Due date unavailable
The Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop and laptop systems.
CORSAIR Value Select - DDR3L - 4 GB - DIMM 240-pin - unbuffered
RAM memory
4 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11 (11-11-11-28)
Low Voltage, Black PCB, unbuffered
Voltage
1.35 V
4 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11 (11-11-11-28)
Non-ECC
Voltage
1.35 V
Scroll to top
