Click to visit BT.com
BT.com
Wishlist
Corsair 430W Builder Series CX 80+ Bronze ATX Power Supply
5.0*
Quicklinx: 8BV9WS00
Mfr#: CP-9020046-UK
Power Rating: 430Watt
Express delivery Order within the next 23 minutes for delivery tomorrow
£42.16
The Corsair Builder Series CX430 PSU is designed for worry-free compatibility for your home desktop PC system build or upgrade. With features usually reserved for premium power supplies, they are a great choice for systems where continuous and reliable power delivery and low noise are essential. Inside you will find a power supply that conforms to universal ATX standards, a power cable, and a clear, detailed Quick Start Guide. Corsair Builder Series power supplies get your system up and running quickly and easily, for years of trouble-free operation.The Builder Series CX430 is the ideal choice for PC builders and upgraders who need a great value, quiet and energy efficient PSU for a low/medium specification home or office PC.
  • Corsair engineering and quality control
  • Plentiful connectors and long cables
  • 80 PLUS© Bronze Certified efficiency
  • Large diameter, thermally controller fan
  • Black housing and all-black sleeved cables and connectors
  • 3-Year Warranty
Physical
  • Form Factor ATX
  • Case Colour Black
  • Width 150mm
  • Depth 140mm
  • Height 86mm
  • Weight 2.06Kg
Specifcations
  • Model: CX430
  • AC Input: 100-240V
  • Input Current: 6.3-3.15A
  • Frequency: 47Hz - 63Hz
  • Max Load Max Output: +3.3V 20A 110W, +5V 20A, +12V 32A 384W, -12V 0.8A 9.6W, +5Vsb 3A 15W
  • Total Power: 430W
  • Warranty: 3 Years Manufacturers Warranty
Corsair CX430 - power supply - 430 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ PS/2
80 PLUS Certification
80 PLUS Bronze
United Kingdom
Input Voltage
AC 90-264 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
430 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x 6 pin PCI Express power , 3 x 4 PIN internal power , 4 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
3 years warranty
ATX12V 2.3/ PS/2
United Kingdom
Input Voltage
AC 90-264 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
430 Watt
Output Current
+3.3V - 20 A , +5V - 20 A , +12V - 32 A , -12V - 0.8 A , +5VSB - 3 A
80 PLUS Bronze
MTBF
100,000 hours
Cooling System
120 mm fan
Over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail
FCC Class B certified, UL, TUV, C-Tick, cUL, CB, CCC, Energy-Related Products (ErP) Lot 6
3 years warranty
Service & Support Details
Limited warranty - 3 years
15 cm
14 cm
8.6 cm
Shipping Width
19.05 cm
Shipping Depth
26.67 cm
Shipping Height
9.855 cm
Shipping Weight
2.32 kg
Corsair 430W Builder Series CX 80+ Bronze ATX Power Supply Bundle deal on Corsair 430W Builder Series CX 80+ Bronze ATX Power Supply
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.62 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£61.69
saving £8.68
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£52.15
Customer reviews
Write a review for the Corsair 430W Builder Series CX 80+ Bronze ATX Power Supply here!
Quiet Power
Reviewed by Charles R. Review Posted 03/06/2013
Not the cheapest, but with power supplies it really is important that you have a reliable one, as the rest of your hardware depends on it.
This one is quiet and efficient. The fan is just audible but not intrusive. The good efficiency is doubly useful: firstly, less heat and therefore a lower speed & quieter fan and, secondly, lower electrical bills.
Average power consumption on this self-build PC is 220W - AMD A10 5800K & Gigabyte MoBo plus the usual peripherals (2 x HDDs, DVD writer) but no separate graphics board. This leaves plenty of power in hand for any peak requirements and the addition of a graphics card when the bank balance allows.
It's my wife's PC and it's been working for a month so far. Only time will tell if its good manners will extend to a long & carefree life.
I was sufficiently impressed to buy a second one for my own self-build PC. The second PC is equally well mannered and has been running for just over a week.
Highly recommended.
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Brand: Corsair
Price Range Inc VAT: 0 - 50
