BT.com
Wishlist
Corsair 430 Watt Builder Series CX 430 Modular Power Supply
Delivery
Standard Due date unavailable
CX Series modular power supply units are an excellent choice for basic system builds and desktop PC computer upgrades, offering high reliability, low noise, and easy installation. The flexible modular cabling system lets you use only the cables you need, and 80 PLUS Bronze certified efficiency means less excess heat, lower noise, and lower power bills. The large-diameter, thermally controlled fan makes the CX Series modular quieter at idle, and the large diameter reduces noise even when you're pushing your system hard. And, the matte black finish, black-sleeved cables and black connectors help give your system a restrained, high-tech look.
CORSAIR CX430M - power supply - 430 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ EPS12V 2.91
80 PLUS Certification
80 PLUS Bronze
3.27 kg
United Kingdom
Input Voltage
AC 90-264 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
430 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 3 x 4 PIN internal power , 4 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
15 cm x 14 cm x 8.6 cm
3 years warranty
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 90-264 V
Input Voltage Range
AC 100 - 240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
430 Watt
Output Current
+3.3V - 20 A , +5V - 20 A , +12V - 32 A , -12V - 0.8 A , +5VSB - 3 A
Efficiency
85%
Modular Cable Management
80 PLUS Bronze
MTBF
100,000 hours
Sleeved cables, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail, temperature controlled fan, semi-modular
Energy-Related Products (ErP) Lot 6
Limited warranty - 3 years
15 cm
14 cm
8.6 cm
3.27 kg
Shipping Width
21.6 cm
Shipping Depth
29 cm
Shipping Height
13 cm
Shipping Weight
3.53 kg
Scroll to top
