BT.com
Wishlist
Corsair 32GB (4x8GB) Vengeance Pro DDR3 DRAM 2133MHz C11
Delivery
Standard Due date unavailable
Corsair Vengeance Pro Series memory kits are designed for overclocking on the latest 3rd and 4th generation Intel® Core™ processor families, with ICs specially selected for performance potential. The aluminum heat spreaders provide superior temperature management and have the aggressive look you want in your gaming rig. Like the original Vengeance line, Vengeance Pro Series DDR3 memory is priced to deliver class-leading value, so your system build budget will go farther.
Speed, stability and reliability...great for overclocking
Corsair Vengeance Pro Series memory modules are designed for overclocking on the latest 3rd and 4th generation Intel® Core™ platforms, with eight-layer PCBs and ICs specially selected for performance potential.
The aluminum heat spreaders provide superior temperature management and have the aggressive look you want in your gaming rig. XMP 1.3 profiles allow for automatic, reliable overclocking.
They’re available in multiple colors to let you match your Vengeance Pro Series memory to your system’s color scheme. As a bonus, they’re priced to deliver class-leading value, so you’ll have more room left in your system build budget.
Built for Overclocking
Each Vengeance Pro Series module is built from an eight-layer PCB and highly-screened memory ICs. The efficient heat spreader provides effective cooling to improve overclocking potential.
Designed to Show Off
The heat spreader doesn’t just allow Vengeance Pro Series to run better – the aggressive yet refined form factor looks great in showcase systems.
Performance and Compatibility
Vengeance Pro Series is optimized for performance on the latest 3rd and 4th generation Intel® Core™ platforms. XMP 1.3 profile support makes stable overclocking easy and automatic.
About Corsair High-Performance Memory
Corsair is the #1 most awarded manufacturer of high-performance memory. We’ve been providing enthusiast-grade memory for PC systems for longer than anyone else, and we offer the broadest product line of any enthusiast memory manufacturer. Whether you're upgrading a system, building a fast and responsive gaming rig, or attempting to break overclocking world records, Corsair has a solution for you.
Corsair Vengeance Pro Series - DDR3 - 32 GB: 4 x 8 GB - DIMM 240-pin
RAM memory
32 GB: 4 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC3-17066)
Latency Timings
CL11 (11-12-12-27)
Dual channel, 8 Layers PCB heatspreader, Intel Extreme Memory Profiles (XMP 1.3), quad channel, anodized aluminum heatspreader, Vengeance Pro Series heatspreader, unbuffered
Voltage
1.5 V
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11 (11-12-12-27)
Non-ECC
Voltage
1.5 V
RAM Performance
SPD - 1333 MHz - 1.5 V - CL9 - 9-9-9-24 , Tested - 2133 MHz - 1.5 V - CL11 - 11-12-12-27
Colour Category
Scroll to top
