BT.com
Wishlist
Corsair 32GB (4x8GB) DDR3 1866Mhz CL9 Dominator GT Enthusiast Desktop Memory Kit
Delivery
Standard Due date unavailable
The Dominator-GT is the ultimate performance solution within the Dominator product line. Limited to only extremely high memory speeds, the Corsair Dominator-GT only uses highly screened IC's to guarantee performance and over-clockability. Using ultra efficient Dual-path Heat Xchange (DHX) cooling technology, the Dominator-GT modules also ship with the airflow fan to maximize heat transfer away from the modules - all the while being stable and reliable. With removable heat sinks, the Dominator-GT modules can even be outfitted with additional upcoming accessories with enhanced features.
Very few components make it into the Dominator family. Even fewer are hand selected to build the Dominator-GT. Corsair's team of engineers run extensive and exhaustive in-house testing and qualification with the premium performance motherboards used by overclockers and ultra enthusiasts.
Corsair Dominator-GT - DDR3 - 32 GB : 4 x 8 GB - DIMM 240-pin
RAM memory
32 GB : 4 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz ( PC3-15000 )
Latency Timings
CL9 ( 9-10-9-27 )
Heat sink, Dual-path Heat Xchange Pro (DHX Pro), Intel Extreme Memory Profiles (XMP 1.3), quad channel , unbuffered
Voltage
1.5 V
32 GB : 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 ( 9-10-9-27 )
Non-ECC
Voltage
1.5 V
Compatible Slots
4 x memory - DIMM 240-pin
Scroll to top
