Click to visit BT.com
BT.com
Wishlist
Corsair 32GB (4x8GB) DDR3 1866Mhz CL10 Vengeance Black Performance Desktop Memory Kit
Quicklinx: 7TZZWS00
Mfr#: CMZ32GX3M4X1866C10
Vengeance Performance Memory modules, 32GB (4x8GB) DDR3 1866MHz CL10 Unbuffered DIMM Memory with XMP 1.3 for AMD, Intel Dual and Quad Channel 2nd Generation Intel Core Processor platforms. Every Vengeance memory module provides users with outstanding performance and high quality. Vengeance memory modules are built using carefully selected DRAM to allow excellent overclocking performance and rock solid stability. Compatible with AMD, Intel P67, Z68 and X79 platforms.
  • 32GB (4x8GB) DDR3 for Intel quad channel platforms
  • 1866MHz with headroom to allow overclocking
  • 1.5V
  • 10-11-10-30 latency
  • Vengeance heat spreader for styling and performance
  • Intel XMP 1.3 (Extreme Memory Profile) Support
  • Also compatible with Intel and AMD dual channel DDR3 Platforms
  • 10 Years Manufacturers Warranty
Spec
  • Density: 8GB (4x8GB Module)
  • Speed: 1866MHz
  • Timing: 10-11-10-30
  • Type: DDR3
  • XMP: version 1.3
  • Format: DIMM
  • Pin Out: 240 Pin
  • Voltage: 1.5V
  • Warranty: 10 Years Manufacturers Warranty
Corsair Vengeance - DDR3 - 32 GB : 4 x 8 GB - DIMM 240-pin
RAM memory
32 GB : 4 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz ( PC3-15000 )
Latency Timings
CL10 ( 10-11-10-30 )
Dual channel, Vengeance heatspreader, Intel Extreme Memory Profiles (XMP 1.3), quad channel , unbuffered
Voltage
1.5 V
32 GB : 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
Non-ECC
Voltage
1.5 V
Compatible Slots
4 x memory - DIMM 240-pin
