BT.com
Wishlist
Corsair 2GB DDR3 1333MHz CL9 DIMM Memory
Corsair 2GB DDR3 1333MHz CL9 DIMM...
Clearance
£15.68
Clearance
While Stocks Last
Hurry, only 2 left in stock!
£15.68
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Corsair Memory is specifically designed for rock-solid stability in demanding applications. Data lines are carefully engineered for noise immunity; clock lines are optimized for minimum skew. All modules use JEDEC-compliant six-layer.
Corsair - DDR3 - 2 GB - DIMM 240-pin
RAM memory
2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz ( PC3-10600 )
Latency Timings
CL9 ( 9-9-9-24 )
Unbuffered
Voltage
1.5 V
2 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 ( 9-9-9-24 )
Non-ECC
Unbuffered
Voltage
1.5 V
Compatible Slots
1 x memory - DIMM 240-pin
£15.68
Save on this ideal PC Build kit!
Save £8.43
£34.90
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Its memory.
Reviewed by Antony on 19/03/2010
Have 3 modules of this memory now, 6gb total. One stick I ordered was faulty and had to be returned, it happens. Its very, very fast memory despite it high CAS rating. Windows 7 index score of 7.4. Not a 5 star rating because it has risen in price.
3* Faulty as well
Reviewed by Anonymous on 02/01/2011
I ordered two sticks and one that I recieved was faulty and had to be sent back to Holland for its RMA. As the other reviewer said, this happens, but the postage cost was high.
Scroll to top
