Corsair 2GB (2x1GB) DDR3 6400 CL5 XMS2 Heatspreader Desktop Memory Kit
Standard 3-5 working days
The TWIN2X2048-6400 is a 2 GByte matched pair of DDR2 SDRAM DIMMs. This part delivers outstanding performance in the latest generation of DDR2-based motherboards. It has been tested extensively in multiple DDR2 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 800MHz at the low latencies of 5-5-5-12-18. This module is also available in a single module part.
Corsair XMS2 Xtreme Performance TwinX Matched - DDR2 - 2 GB: 2 x 1 GB - DIMM 240-pin
RAM memory
2 GB: 2 x 1 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Data Integrity Check
800 MHz (PC2-6400)
Latency Timings
CL5 (5-5-5-18)
1.9 V
2 GB: 2 x 1 GB
Upgrade Type
DIMM 240-pin
800 MHz (PC2-6400)
Latency Timings
CL5 (5-5-5-18)
Chips Organization
64 x 8
1.9 V
Compatible Slots
2 x memory - DIMM 240-pin
Customer reviews
Write review Read all The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Top Quality
Reviewed by Anonymous on 02/06/2007
This is top quality RAM. Very pleased with it so far.
5* Gr8 Memory
Reviewed by Anonymous on 17/07/2007
This memory is gr8, easy to install, no probs.
System is
AM2 5600+ 2.8Ghz
2GB Mem
250GB HD
512MB Graphics
5* Super
Reviewed by Anonymous on 08/04/2008
Excellent RAM! Now have 4GB and Vista runs like it should :)
5* Brilliant Overclockable Memory
Reviewed by Chobbit on 19/03/2009
Okay so this is my second review, had the memory for 3 months now without a single problem. I got brave and decided to do some overclocking and they are brilliant at that. Both sticks are now running at 4-4-4-12 and i've been able to increase their FSB's from 400 (800FSB) to 450 (900FSB) stably with no problems. -Note- i've left my Memory voltages set to Auto, so if your not able to I don't know what voltage you would need to set to achieve this manually. But yeah amazing overclockable Memory
5* Built PC with slightly higher budget and this flies!
Reviewed by TXRX on 19/04/2007
This is good ram. Solid and reliable. Perfect pairing on an Intel Dual core or quad core.
5* best..
Reviewed by James on 14/01/2008
This is very good memory -I've bought two sets.
5* Great
Reviewed by Chobbit on 06/01/2009
Bargain, Definetly Memory worth buying.
Only had the memory a short time so not sure about reliability yet, Easy to install though, looking else where people have claimed it will do timings of 4-4-4-12 by increasing voltage to 2.353 but i'm not risking it and set it manually in the Bios to 5-5-5-12 which runs stable and does the job.
The memory alone has allowed me run Far Cry 2 fine on very high 1280x1024 settings, instead of on normal 1024x768 settings i had to resort too previously.
5* Very Good
Reviewed by Youshless on 01/06/2007
Excellent memory, sturdy, fast and you dont get that, "oh my god, am i going to break this" kind of feeling when you install it.
Intel e6600
Nvidia 7900GTX
550Watt Antec Case
2Gb Memory
5* Brilliant Memory, Very Easy to Install
Reviewed by Stephen on 28/12/2007
I previously bought a pair in June when I was building a new computer and they have performed faultlessly and proved very reliable and fast.
I have now just bought another pair to bring me up to 4GB due to doing a lot of heavy graphic and video work and again I am very impressed. What more they are now half the price from when I got my original pair. They are so easy to install that I showed my eight year old how to install them and then watched as he installed them with no problems at all. He now wants us to buy parts for the two of us to build his first computer.
In my Vista system my memory scores 5.9 in the Windows Experience Index.
5* good memory but
Reviewed by on 28/07/2008
Just had 1 of these modules go on me after nearly 2 years, but corsair have a lifetime warenty so there replacing them
Scroll to top
