BT.com
Wishlist
Corsair 2GB (2x1GB) DDR2 533Mhz CL4 Value Select 240 Pin Desktop Memory Kit
Delivery
Standard 3-5 working days
Corsair Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop systems.
Corsair Value Select - DDR2 - 2 GB: 2 x 1 GB - DIMM 240-pin
RAM memory
2 GB: 2 x 1 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
533 MHz (PC2-4200)
Unbuffered
Voltage
1.8 V
ABIT AL8, AW8, LP-80, 81, NI8; AOpen i915; ASUS P5AD2, P5LD2, P5ND2, P5WD2; Biostar N4SIE, P4TAW; Chaintech V925, Z925; ECS 915, PF21, PF4; EPoX EP-5EGA+, 5LWA+, 5NVA+; FIC Crusader II CS2; Foxconn 915A01, 915M03, 925A01; Gigabyte GA-8I945, 8I955; MSI 945, 955, P4N; SUPERMICRO SUPER P8SCi
2 GB: 2 x 1 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
533 MHz (PC2-4200)
Non-ECC
Unbuffered
Module Configuration
128 x 64
Voltage
1.8 V
Compatible Slots
2 x memory - DIMM 240-pin
ABIT AA8 DuraMAX, AA8-3rd Eye, AA8XE, AL8, AW8, AW8-MAX, Fatal1ty AA8XE, LP-80, LP-81, NI8 SLI , AOpen i915Ga-EFRII, i915Pa-EFRII , ASUS P4GD1, P5AD2 Deluxe, P5AD2 Premium, P5AD2-E Deluxe, P5AD2-E Premium, P5GD2, P5GD2 Deluxe, P5GD2 Premium, P5GDC Deluxe, P5GDC-V Deluxe, P5LD2 AiLife Series, P5ND2-SLI Deluxe, P5WD2 AiLife Series, P5WD2 Premium AiLife Series , Biostar N4SIE-A7, P4TAW Extreme, P4TGP 775 , Chaintech V925X ZENITH VE, Z925X ZENITH , DFI 925X-T2, UT 915P-T12 , ECS 915G-A, 915P-A, PF21 Extreme, PF4 Extreme , EPoX EP-5EGA+, EP-5LWA+, EP-5NVA+ SLI , FIC P4M-915GD1, P4M-915GD2, P4M-915PD1, P4M-915PD2 , FIC Crusader II CS2-P4M915GD1, CS2-P4M915GD2 , Foxconn 915A01-P-8EKRS2, 915M03-G-8EKRS2, 925A01-8EKRS2 , Gigabyte GA-8AENXP-D, GA-8ANXP-D, GA-8GPNXP Duo, GA-8I915P Duo Pro, GA-8I915P Duo Pro-A, GA-8I915P Duo-A, GA-8I915P-MF, GA-8I945G, GA-8I945G PRO, GA-8I945GMF, GA-8I945P Dual Graphic, GA-8I945P PRO, GA-8I945P-G, GA-8I955X PRO, GA-8I955X Royal , Intel Desktop Board D915GEV, D915GUX, D915PBL, D915PCM, D915PCY, D925XBC, D925XCV, D925XEBC2, D925XECV2 , MSI 915G Combo-FR, 915G Neo2 Platinum, 915P Combo-FR, 915P Neo2 Platinum, 915P Neo2-FR, 925X Neo Platinum-54g, 925XE Neo Platinum, 945P Neo-F, 945P Platinum, 955X Platinum, P4N Diamond , Soltek SL-915GPRO-FGR , SUPERMICRO SUPER P8SAA, P8SCi , Tyan Tomcat i925X S5130
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
2* Faulty
Reviewed by Chris on 06/02/2008
I bought this along with other parts, One of the stcicks now has stopped workin after a few weeks, and you cant just send one back, which means i will be without a working pc for at least two weeks, i think this is the wrong way about dealing with customers especially after spending so much with this company, I am dissapointed.
Scroll to top
