BT.com
Wishlist
Corsair 2GB (1x2GB) DDR2 800Mhz CL5 Value Select SODIMM 200 Pin Notebook Memory Module
Delivery
Standard Due date unavailable
The Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop and laptop systems.
CORSAIR Value Select - DDR2 - 2 GB - SO-DIMM 200-pin
RAM memory
2 GB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Latency Timings
CL5 (5-5-5-18)
Unbuffered
2 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
SO-DIMM 200-pin
Speed
800 MHz (PC2-6400)
Latency Timings
CL5 (5-5-5-18)
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 200-pin
Scroll to top
