BT.com
Wishlist
Corsair 2.0 Flash Padlock 2 32GB 256-bit AES USB Flash Drive
Delivery
Standard Due date unavailable
Corsair Flash Padlock 2 is designed for confidential and sensitive information. Your files are protected from snooping with 256-bit AES hardware encryption, and the durable rubber housing helps protect them from the elements, too. An easy-to-use, integrated PIN pad means no software is needed, so Padlock works equally well with Microsoft Windows, Mac OSX, and even Linux-based systems.
Corsair Flash Padlock 2 - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
32 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
Apple MacOS 9.x or later, Linux Kernel 2.4.2 or later, Microsoft Windows 2000/ME/XP/Vista/7
3 years warranty
USB flash drive
Storage Capacity
32 GB
Hardware Encryption
256-bit AES
Compatibility
Non-specific
Interface Type
USB 2.0
Shockproof, auto-locking, customizable PIN, ruggedized
Plug and Play
Limited warranty - 3 years
Scroll to top
