BT.com
Wishlist
Corsair 16GB (4x4GB) Vengeance LPX DDR4 3400MHz 1.35V XMP2.0 Red
Corsair 16GB (4x4GB) Vengeance LPX...
£322.69
Hurry, only 1 left in stock!
£322.69
Add to wishlist
Delivery
Standard 1-3 working days
Vengeance Low Profile heat spreaders have a reduced height of 1.03". They're designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or any other space-constrained application where you need high-performance memory but standard Vengeance modules might not fit.
Corsair Vengeance LPX - DDR4 - 32 GB : 4 x 8 GB - DIMM 288-pin
RAM memory
32 GB : 4 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3400 MHz ( PC4-27200 )
Latency Timings
CL16 ( 16-18-18-36 )
Dual channel, 8 Layers PCB heatspreader, quad channel, anodized aluminum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), Vengeance LPX low profile heatspreader , unbuffered
Voltage
1.35 V
32 GB : 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
Non-ECC
Voltage
1.35 V
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15-36 , Tested - 3400 MHz - 1.35 V - CL16 - 16-18-18-36
Colour Category
Red
Corsair 16GB (4x4GB) Vengeance LPX DDR4 3400MHz 1.35V...
£322.69
Save on this ideal PC Build kit!
Save £10.36
£342.24
Scroll to top
