Click to visit BT.com
BT.com
Wishlist
Corsair 16GB (4x4GB) DDR3 1866Mhz CL9 Vengeance Blue Performance Desktop Memory Kit
Quicklinx: 86RJWS00
Mfr#: CMZ16GX3M4A1866C9B
Standard delivery Delivered within 3-5 working days
Vengeance Performance Memory modules, 16GB (4x4GB) DDR3 1866MHz CL9 Unbuffered DIMM Memory with XMP 1.3 for Intel Dual and Quad Channel Core™ Processor platforms, including 3rd generation Intel Core™ processors. Every Vengeance memory module provides users with outstanding performance and high quality. Vengeance memory modules are built using carefully selected DRAM to allow excellent overclocking performance and rock solid stability.
Key Features
  • 16GB (4x4GB) DDR3 for Intel Dual and quad channel platforms
  • 1866MHz with headroom to allow overclocking
  • 9-10-9-27 latency
  • Vengeance Red heat spreader for styling and performance
  • Intel XMP 1.3 (Extreme Memory Profile) Support
  • Compatible with Intel Z77 and X79 Platforms
  • Limited Lifetime Warranty
  • Density: 16GB (4x4GB Module)
  • Speed: 1866MHz
  • Timing: 9-10-9-27
  • Type: DDR3
  • XMP: version 1.3
  • Format: DIMM
  • Pin Out: 240 Pin
  • Voltage: 1. 5V
Corsair Vengeance - DDR3 - 16 GB : 4 x 4 GB - DIMM 240-pin
RAM memory
16 GB : 4 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz ( PC3-14900 )
Latency Timings
CL9 ( 9-10-9-27 )
Intel Extreme Memory Profiles (XMP 1.3), quad channel, Vengeance blue heat spreader , unbuffered
Voltage
1.5 V
16 GB : 4 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 ( 9-10-9-27 )
Non-ECC
Voltage
1.5 V
Compatible Slots
4 x memory - DIMM 240-pin
Resources
The following resources are available for the Corsair 16GB (4x4GB) DDR3 1866Mhz CL9 Vengeance Blue Performance Desktop Memory Kit
