BT.com
Wishlist
Corsair 16GB (4 x 4GB) Dominator Platinum DDR4 2800MHz DIMM 240pin
Delivery
Standard Due date unavailable
Dominator Platinum high-performance DDR4 memory is designed for world-class system builds. It's built with hand-screened ICs, undergoes rigorous performance testing, and incorporates patented DHX cooling for reliable performance in demanding environments.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards, and modules are compatibility-tested across multiple X99 Series motherboards for reliably fast performance. Extracting maximum performance is easy -- built-in XMP 2.0 support gives you trouble-free, automatic overclocking.
Dominator Platinum modules work with the Corsair Link system for temperature monitoring, and you can even enhance the subtle white LED lighting by adding a light bar kit (available separately) to match or contrast it with your system.
  • Hand Screened Performance IC's: Using best of the best IC's available leads to highly overclockable memory
  • DHX cooling: Patented technology pulls performance-robbing heat away from the modules and allows Dominator memory to run at a cooler temperature.
  • Customizable light bar: Customize the look and feel of your memory with upgradable light bars and Dominator Airflow LED fan.
  • Performance and Compatibility: Dominator Platinum DDR4 is optimized and compatibility tested for the latest Intel X99 Series motherboards and offers higher frequencies, greater bandwidth, and lower power consumption. XMP 2.0 support for trouble-free automatic overclocking.
  • Corsair Link compatibility: The Corsair Link Digital connector allows you to monitor your memory's temperature for an optimal combination of performance and stability.
Specs
  • Density: 16GB (4x4GB)
  • Speed: 2800MHz
  • Timing: 16-18-18-36
  • Voltage: 1.20V
  • Format: DIMM
  • Pin Out: 284 Pin
  • Intel XMP 2.0
  • Light Bar: Polished Aluminum
  • Light Pipe: White LED
  • Compatibility: Intel® X99 platform
CORSAIR Dominator Platinum - DDR4 - 16 GB: 4 x 4 GB - DIMM 288-pin
RAM memory
16 GB: 4 x 4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2800 MHz (PC4-22400)
Latency Timings
CL16 (16-18-18-36)
Temperature monitoring, Dual-path Heat Xchange (DHX), aluminium heat spreader, activity LED's, dual channel, quad channel, Corsair Link connector, Corsair Dominator Platinum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
16 GB: 4 x 4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL16 (16-18-18-36)
Non-ECC
Voltage
1.2 V
Scroll to top
