BT.com
Wishlist
Corsair 16GB (2x8GB) Vengeance Pro DDR3 1866MHz 240pin DIMM Red
Delivery
Standard Due date unavailable
Vengeance Low Profile heat spreaders have a reduced height of 1.03". They're designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or any other space-constrained application where you need high-performance memory but standard Vengeance modules might not fit.
Corsair Vengeance Pro Series - DDR3 - 16 GB: 2 x 8 GB - DIMM 240-pin
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz (PC3-15000)
Latency Timings
CL10 (10-11-10-30)
Dual channel, 8 Layers PCB heatspreader, Intel Extreme Memory Profiles (XMP 1.3), anodized aluminum heatspreader, Vengeance Pro Series heatspreader, unbuffered
Voltage
1.5 V
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL10 (10-11-10-30)
Non-ECC
Voltage
1.5 V
Colour Category
Black, red
Scroll to top
