BT.com
Wishlist
Corsair 16GB (2x8GB) Vengeance Performance SODIMM 2400MHz CL16 DDR4
Delivery
Standard Due date unavailable
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
Corsair Vengeance - DDR4 - 16 GB: 2 x 8 GB - SO-DIMM 260-pin
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL16 (16-16-16-39)
Unbuffered
Voltage
1.2 V
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL16 (16-16-16-39)
Non-ECC
Unbuffered
Voltage
1.2 V
Colour Category
Scroll to top
