BT.com
Wishlist
Corsair 16GB (2x8GB) DDR3 1866Mhz CL9 Vengeance Black Performance Desktop Memory Kit
Free delivery
Delivery
Standard Due date unavailable
Corsair high performance Vengeance memory module 16GB (2x8GB) 1866MHz 9-10-9-27, 1.5V AMD and Intel Dual Channel Processor platforms, including 2nd and 3rd generation Intel Core i7 and i5 systems. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
  • 16GB (2x8GB) DDR3 for AMD and Intel Dual Channel processors
  • 1866MHz
  • 9-10-9-27 latency
  • Vengeance heat spreader for styling and performance
  • Intel XMP 1.3 (Extreme Memory Profile) Support
  • 10 Years Manufacturers Warranty
  • Density: 16GB (2x8GB Module)
  • Speed: 1866MHz
  • Timing: 9-10-9-27
  • Type: DDR3
  • XMP: version 1.3
  • Format: DIMM
  • Pin Out: 240 Pin
  • Voltage: 1.5V
  • Warranty: 10 Years Manufacturers Warranty
Corsair Vengeance - DDR3 - 16 GB : 2 x 8 GB - DIMM 240-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz ( PC3-15000 )
Latency Timings
CL9 ( 9-10-9-27 )
Dual channel, Vengeance heatspreader, Intel Extreme Memory Profiles (XMP 1.3) , unbuffered
Voltage
1.5 V
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 ( 9-10-9-27 )
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
Scroll to top
