Click to visit BT.com
BT.com
Wishlist
Corsair 16GB (2x8GB) DDR3 1866Mhz CL10 Vengeance Red Performance Desktop Memory Kit
Quicklinx: 81QGWS00
Mfr#: CMZ16GX3M2A1866C10R
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
Corsair Vengeance - DDR3 - 16 GB : 2 x 8 GB - DIMM 240-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz ( PC3-15000 )
Latency Timings
CL10 ( 10-11-10-30 )
Dual channel, Intel Extreme Memory Profiles (XMP 1.3), Vengeance red heat spreader , unbuffered
Voltage
1.5 V
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
