Click to visit BT.com
BT.com
Wishlist
Corsair 16GB (2x8GB) DDR3 1600Mhz CL10 Vengeance SODIMM Performance Notebook Memory Kit
5.0*
Quicklinx: 82MXWS00
Mfr#: CMSX16GX3M2A1600C10
Type: DDR3 SDRAM
Capacity: 16GB
Connection: SO-DIMM 204-pin
Speed: 1600MHz
Data Integrity: Non-ECC
Express delivery Order within the next 4 hours for delivery tomorrow
Hurry, only 2 left in stock!
£75.22
CORSAIR high performance Vengeance SODIMM memory kit, 16GB (2x8GB) 1600MHz 10-10-10-27, 1.5V, allows you to automatically boost performance of your without bios reconfiguration. Slim and attractive design to ensure physical compatibility with all 2nd Generation Intel Core™ i5 and i7 notebooks. Each module is built using carefully selected DRAM to allow excellent stability and is backed by Corsair's limited lifetime warranty.
Key Features
  • 16GB (2x8GB) DDR3 SODIMM kit for 2nd Generation Intel Core™ i5 and i7 notebooks.
  • 1600MHz
  • 10-10-10-27 latency
  • 1.5V
  • Auto-overclocking (no bios configuration required)
  • Limited Lifetime Warranty
  • Density: 16GB (2x8GB Module)
  • Speed: 1600MHz
  • Timing: 10-10-10-27
  • Type: DDR3
  • Format: SODIMM
  • Pin Out: 204 Pin
  • Voltage: 1.5V
Corsair Vengeance - DDR3 - 16 GB : 2 x 8 GB - SO-DIMM 204-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL10 ( 10-10-10-27 )
Dual channel , unbuffered
Voltage
1.5 V
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - SO-DIMM 204-pin
Corsair 16GB (2x8GB) DDR3 1600Mhz CL10 Vengeance SODIMM  Performance Notebook Memory Kit Bundle deal on Corsair 16GB (2x8GB) DDR3 1600Mhz CL10 Vengeance SODIMM Performance Notebook Memory Kit
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.62 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£94.75
saving £8.68
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£85.21
Customer reviews
Write a review for the Corsair 16GB (2x8GB) DDR3 1600Mhz CL10 Vengeance SODIMM Performance Notebook Memory Kit here!
Awesome
Reviewed by Stuart. Review Posted 27/12/2013
Got bought this memory for Christmas, and it's fantastic, incredibly fast. Running it with an i5 2.2ghz CPU and a Samsung SSD. Probably a bit over kill to have 16GB but better than not enough! A bit pricey, but well worth it. With my previous RAM I was frequently getting warning messages about memory running low, especially when I was using Fireworks, Photoshop and had loads of tabs open in Firefox. This is no longer a problem. Fitting, as usual with laptop memory, takes about 2 minutes.
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
Careful won't work with 4th Gen Intel Nuc
Reviewed by DK. Review Posted 22/01/2014
Careful won't work with 4th Gen Intel Nuc, you need 1.35V memory. The older gens supported both but its a no go with 4th Gen. See: http://www.intel.com/support/motherboards/desktop/sb/CS-034475.htm
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Type: DDR3 SDRAM
Capacity: 16GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL10
Standard: PC3-12800
Brand: Corsair
Stock Status: Clearance
Price Range Inc VAT: 50 - 100
