BT.com
Wishlist
Corsair 16GB (2x8GB) DDR3 1600Mhz CL10 Vengeance Low Profile Black Performance Desktop Memory Kit
Corsair 16GB (2x8GB) DDR3 1600Mhz...
£127.92
35 in stock
£127.92
Add to wishlist
Delivery
Standard 1-3 working days
Vengeance LP Performance Memory modules, 16GB (2x8GB) DDR3 1600MHz CL10 Unbuffered DIMM Memory with XMP 1.3 for AMD, Intel Processor platforms, including 2nd and 3rd generation Intel Core i7 and i5 systems. Every Vengeance memory module provides users with outstanding performance and high quality. Vengeance memory modules are built using carefully selected DRAM to allow excellent overclocking performance and rock solid stability.
  • 16GB (2x8GB) DDR3
  • 1600MHz with headroom to allow overclocking
  • 10-10-10-27 latency
  • Vengeance LP heat spreader for styling and performance
  • Intel XMP 1.3 (Extreme Memory Profile) Support
  • Also compatible
  • 10 Years Manufacturers Warranty
  • Density: 16GB (2x8GB Module)
  • Speed: 1600MHz
  • Timing: 10-10-10-27
  • Type: DDR3
  • XMP: version 1.3
  • Format: DIMM
  • Pin Out: 240 Pin
  • Voltage: 1.5V
  • Warranty: 10 Years Manufacturers Warranty
Corsair Vengeance - DDR3 - 16 GB : 2 x 8 GB - DIMM 240-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL10 ( 10-10-10-27 )
Dual channel, Intel Extreme Memory Profiles (XMP 1.3), Vengeance low profile heatspreader , unbuffered
Voltage
1.5 V
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
Scroll to top
