BT.com
Wishlist
Corsair 16GB (2x8GB) DDR3 1600Mhz CL10 Vengeance Black Performance Desktop Memory Kit
Corsair 16GB (2x8GB) DDR3 1600Mhz...
£129.12
£129.12
Add to wishlist
Delivery
Standard Due date unavailable
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
Corsair Vengeance - DDR3 - 16 GB: 2 x 8 GB - DIMM 240-pin
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL10 (10-10-10-27)
Intel Extreme Memory Profiles (XMP), dual channel, Vengeance heatspreader, unbuffered
Voltage
1.5 V
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL10 (10-10-10-27)
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
Scroll to top
