Click to visit BT.com
BT.com
Wishlist
Corsair 16GB (2 x 8GB) Vengeance Pro Red DDR3 1866MHz CL9
5.0*
Quicklinx: 8QJ7WS00
Mfr#: CMY16GX3M2A1866C9R
Type: DDR3 SDRAM
Capacity: 16GB
Connection: DIMM 240-pin
Speed: 1866MHz
Data Integrity: Non-ECC
£67.44
Corsair Vengeance Pro Series memory modules are designed for overclocking on the latest 3rd and 4th generation Intel® Core™ platforms, with eight-layer PCBs and ICs specially selected for performance potential. The aluminum heat spreaders provide superior temperature management and have the aggressive look you want in your gaming rig. XMP 1.3 profiles allow for automatic, reliable overclocking.
They're available in multiple colours to let you match your Vengeance Pro memory to your system's color scheme. As a bonus, they're priced to deliver class-leading value, so you'll have more room left in your system build budget.
Corsair Vengeance Pro Series - DDR3 - 16 GB : 2 x 8 GB - DIMM 240-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz ( PC3-15000 )
Latency Timings
CL9 ( 9-10-9-27 )
Aluminium heatsink, dual channel, Vengeance heatspreader, Intel Extreme Memory Profiles (XMP 1.3) , unbuffered
Voltage
1.5 V
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 ( 9-10-9-27 )
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
Corsair 16GB (2 x 8GB) Vengeance Pro Red DDR3 1866MHz CL9 Bundle deal on Corsair 16GB (2 x 8GB) Vengeance Pro Red DDR3 1866MHz CL9
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.62 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£86.97
saving £8.68
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£77.43
Customer reviews
Write a review for the Corsair 16GB (2 x 8GB) Vengeance Pro Red DDR3 1866MHz CL9 here!
Best looking RAM I have ever owned ;)
Reviewed by Tom. Review Posted 19/08/2013
Amazing product, images do not do this product justice, I was expectng cheap plastic looking effect, in fact I got a sweet looking metallic colour that went very nice with my motherboard and graphics combination (wish I could link a photo). Very well packaged, easy to install, instantly recognised in my Asus BIOS for its timings and frequency. Corsair are a great manufacturer, worth every penny. BT service & delivery is fanastic as well (thank you).
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Type: DDR3 SDRAM
Capacity: 16GB
Speed: 1866MHz
Registered/Buffered: Unbuffered
CAS Latency: CL9
Standard: PC3-15000
Brand: Corsair
Price Range Inc VAT: 50 - 100
