BT.com
Wishlist
Corsair 16GB (2 x 8GB) DDR3 1600MHz 204-pin SODIMM CL11
Delivery
Standard Due date unavailable
The Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop and laptop systems.
Corsair Value Select - DDR3 - 16 GB : 2 x 8 GB - SO-DIMM 204-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL11 ( 11-11-11-28 )
Unbuffered
Voltage
1.5 V
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
Non-ECC
Unbuffered
Voltage
1.5 V
Compatible Slots
2 x memory - SO-DIMM 204-pin
Scroll to top
