BT.com
Wishlist
Corsair 1050W Gold Professional Series 80PLUS Gold Modular PSU
Free delivery
Delivery
Standard Due date unavailable
Compatible with 4th generation Intel® Core™ series processors
Corsair Professional Series power supply is designed for enthusiasts and gamers who demand high performance, high efficiency, the flexibility of modular cables, and unflinching reliability. Designed and engineered using cutting-edge technology, Corsair Professional Series power supply is built to the highest quality standards, and delivers the features and performance that technology enthusiast's demand. Corsair Professional Series power supply is built using industrial grade electrical components, ensuring the stable, clean and reliable voltages that are essential for high-end gaming PCs and workstations.
The Corsair Professional Series HX1050 PSU utilizes advanced DC-to-DC circuitry, and exceeds the requirement for 80 PLUS silver certification standards, for up to 88% energy-efficiency. This reduces wasted energy, reducing energy bills, and lowers the amount of excess heat generated, allowing the cooling fan to spin more slowly and quietly. Corsair Professional Series power supply is built using industrial grade electrical components, ensuring the stable, clean and reliable voltages that are essential for high-end gaming PCs and workstations.
Corsair Professional Series power supply boasts a semi-modular cabling configuration that uses low-profile, flat modular cables, which reduces air friction to help maximize airflow through the computer chassis. The modular design also simplifies installation as it allows flexibility in utilizing this cable which is needed.
  • Fanless operation at low power loads
  • Low profile, black modular cables
  • Continuous power output at 50C
  • 80 PLUS® Gold Certified efficiency
  • Multiple GPU ready
  • Industrial grade components, like 105C high quality capacitors
  • 7-Year Warranty
Corsair HX1050 - power supply - 1050 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31/ EPS12V 2.92
80 PLUS Certification
80 PLUS Gold
United Kingdom
Input Voltage
AC 120-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1050 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 12 x 4 PIN internal power , 12 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector
Cooling System
140 mm fan
Cable bag
15 cm x 20 cm x 8.6 cm
7 years warranty
United Kingdom
Input Voltage
AC 120-240 V
Input Voltage Range
AC 90 - 264 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1050 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 87.5 A , -12V - 0.8 A , +5VSB - 3 A
80 PLUS Gold
Cable bag
Power cable kit
MTBF
100,000 hours
Cooling System
140 mm fan
Fan speed monitoring, over current protection, over voltage protection, undervoltage protection, short-circuit protection, single 12V rail, dual ball bearing cooling fan
FCC Class B certified, TUV, C-Tick, CB, CCC, cTUVus
Limited warranty - 7 years
15 cm
20 cm
8.6 cm
Resources
The following resources are available for the Corsair 1050W Gold Professional Series 80PLUS Gold Modular PSU
Scroll to top
