BT.com
Wishlist
Corsair 1000W Professional Series HX1000W ATX PSU
Delivery
Standard Due date unavailable
The HX1000W joins the family of well received HX Series Enthusiast Grade Power Supplies known for their rock solid stability, enhanced modular cable design and high efficiency. The Corsair HX1000W Power Supply sets a standard by which all other high wattage power supplies will be judged.
The Corsair HX1000W features six PCI-Express connectors, both 6-pin and 8-pin compatible, to power multiple high-end graphics cards and two EPS12V connectors for dual CPU configurations. The truly independent dual transformer, dual rail design allow for optimum load balancing resulting in greater performance and stability. Industrial-grade 105°C primary, secondary and solid state capacitors provide up to four times the lifespan of traditional components.
The HX1000W not only delivers one thousand watts of clean power for the highest performance enthusiast systems, it does so at greater than 80% efficiency thanks to the double-forward switching design and multiple rail DC-to-DC converter. Due to its best-in-class efficiency the HX1000W is able to run cool and quiet with only a single 140mm thermally controlled fan.
CORSAIR Professional Series HX1000W - power supply - 1000 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.2/ EPS12V 2.91
80 PLUS Certification
80 PLUS
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1000 Watt
Input Connectors
1
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power , 10 x 15 pin Serial ATA power , 10 x 4 PIN internal power , 2 x 4 PIN mini-power connector
Cooling System
140 mm fan
15 cm x 20 cm x 8.6 cm
5 years warranty
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Input Connectors
1
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1000 Watt
Modular Cable Management
80 PLUS
4 x power 15 pin SATA to 4 pin adapter , 4 x power 4 pin to mini-power 4 pin Y-adapter , 5 x power 8 pin to 4 pin ATX12V + 6 pin PCI Express Y-adapter
MTBF
100,000 hours
Cooling System
140 mm fan
Thermal monitoring, over current protection, over voltage protection, overpower protection, undervoltage protection, dual 12V rails, short-circuit protection, dual ball bearing cooling fan, semi-modular
C-Tick, CISPR 22 Class B, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, CCC, FCC Part 15, FCC Part 2, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03
Limited warranty - 5 years , Technical support - 5 years
15 cm
20 cm
8.6 cm
Scroll to top
