Click to visit BT.com
BT.com
Wishlist
CoolerMaster Silent Pro M2 720, 720W 80 Plus, 12V Single Rail, Modular
Quicklinx: 8K4KWS00
Mfr#: RS720-SPM2D3-UK
Silent Pro series is a single rail power supply from Cooler Master that's addressing a growing market demand for powerful single rail PSU. With up to 50 A on the 12 V rail, the Silent Pro series delivers where it counts and won't have any problems powering even with the most demanding SLI or CrossFire systems.
CoolerMaster Silent Pro M2 720W - power supply - 720 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31/ EPS12V 2.92
80 PLUS Certification
80 PLUS Bronze
Europe
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
720 Watt
Output connectors
1 x power 24 pin ATX , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 5 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System
135mm fan
15 cm x 8.6 cm x 18 cm
5 years warranty
Europe
Input Voltage
AC 100-240 V
Input Voltage Range
AC 90 - 264 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
720 Watt
Output Current
+3.3V - 20 A , +5V - 25 A , +12V - 58 A , -12V - 0.3 A , +5VSB - 2.5 A
Efficiency
85%
80 PLUS Bronze
MTBF
100,000 hours
Cooling System
135mm fan
Overheat protection, over voltage protection, overpower protection, SLI ready, CrossFire ready, undervoltage protection, short-circuit protection, single 12V rail
UL, TUV, C-Tick, BSMI, GOST, CCC, FCC, RoHS, ErP Ready, KC
5 years warranty
Service & Support Details
Limited warranty - 5 years
15 cm
8.6 cm
18 cm
