BT.com
Wishlist
CoolerMaster Silencio RC-550 Mid Tower Case No PSU
Delivery
Standard Due date unavailable
Near silent operation and prepared to take on powerful hardware, the Cooler Master Silencio is able to keep high-end setups running cool and quiet. Sound proofing on both side panels assist in vastly reducing noise levels. A sleek mirror finish front panel and clean lines present a minimalist design aesthetic that speaks to its silent interior. The benefits of elegance and silence, combined with the functionality of built in SuperSpeed USB 3.0, a multifunction SD card reader, and 3.5" X-dock HDD hotswap all make the Silencio a giant among its kind.
Cooler Master Silencio 550 - mid tower - ATX
System cabinet
Mid tower
Built-in Devices
Card reader
I/O Connectors
1 x USB 3.0 , 1 x USB 2.0 , 1 x microphone , 1 x audio line-out
Supported Motherboards
ATX, microATX
System Cabinet Features
Front panel door, removable HDD rack, CPU cut-out
No power supply
Specification Compliance
ATX / PS/2
21 cm x 50.5 cm x 45.2 cm
9.2 kg
2 years warranty
Mid tower
Max Mainboard Size
ATX
ATX, microATX
ATX / PS/2
Internal Bays Qty
7
Front Accessible Bays Qty
3
Supported Flash Memory Cards
SD Memory Card
Built-in Devices
Card reader
Cooling System
Front: 120 mm fan x 1 / intake / 800 rpm , Front: 120 mm fan mount x 1 , Rear: 120 mm fan x 1 / exhaust / 800 rpm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 6 (total) / 6 (free) x internal - 3.5" , 1 (total) / 1 (free) x front accessible - 5.25"/ 3.5" shared , 1 (total) / 1 (free) x internal - 2.5" / 3.5" shared
Expansion Slots
7 x Expansion Slot
1 x USB 3.0 , 1 x USB 2.0 , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack
No power supply
Max Supported Qty
1
21 cm
50.5 cm
45.2 cm
9.2 kg
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Excellent Case
Reviewed by Niki on 18/11/2012
This case is a natural progression from the C-Silio case, and it's nice to see that CoolerMaster listened to criticisms and got just about everything right. It really is an excellent case. Black inside and out, it's great looking too. They even provide a mount for SSD drives, and removable 3.5" drives. My only tiny criticism is that the 3.5" bays are mounted sideways, which seems like a great idea, but actually isn't because it's difficult to route the SATA cables without bending them beyond their minimum radius. Apart from that, though, it's a great case. The intake for the PSU at the bottom of the case is of course unusable if you have carpets, but that's not a problem, you just mount the PSU the other way up! Oh, and there is a large hole in the motherboard mount plate under the CPU to accommodate a underside fixing plate for a heat-sink like a Zalman, just in case you wondering!
3* Shame about noisy fan
Reviewed by Ads on 15/07/2013
This case is very nicely constructed, easy to work on and provides more than adequate drive bays, cable routing options, etc, plus SD card reader on the front looks good (ie, not cheap!).
The problem with this "silent" case is that the front large fan makes a lot of noise. The rear fan is very quiet so I think the fan is either mounted badly or faulty.
Scroll to top
