BT.com
Wishlist
CoolerMaster Seidon 120V R2 CPU Liquid Cooler Kit
CoolerMaster Seidon 120V R2 CPU...
£52.03
£52.03
Add to wishlist
Delivery
Standard Due date unavailable
The Seidon 120V ver. 2 is the AIO watercooler that boasts an excellent value for performance. The compact radiator fits in virtually every case. Thanks to a premium Silencio FP fan with strong air pressure, Seidon can operate silently or unleash a powerful cooling storm at your command. Durable FEP Tubing provides the advantages of nearly no moisture absorption, high thermal stability and high pressure tolerance which all contribute to a long operating life.
Cooler Master Seidon 120V ver.2 - liquid cooling system
Liquid cooling system
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket
Heatsink Material
Aluminium
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Loop dynamic bearing
Rotation Speed
800-2400 rpm
Air Flow
16.5-76 cfm
Noise Level
6.5 - 27 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Variable fan speed, Pulse-width modulation (PWM) support, Micro Channel Technology, Silencio FP fan
Blue LED lighting
2 years warranty
Heatsink & Fan
Compatible With
Heatsink Material
Aluminium
Heatsink Dimensions
154 mm x 119 mm x 27 mm
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
800-2400 rpm
Air Flow
16.5-76 cfm
Air Pressure
0.48-4.8 mm
Noise Level
6.5 - 27 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.1 A
Power Consumption
1.2 W
Blue LED lighting
£52.03
Save on this ideal PC Build kit!
Save £8.40
£71.25
Scroll to top
