BT.com
Wishlist
CoolerMaster Notepal Ergostand 5 height settings Stand with 2x140mm Fans
CoolerMaster Notepal Ergostand 5...
£35.13
£35.13
Add to wishlist
Delivery
Standard Due date unavailable
The Cooler Master NotePal ErgoStand III is a premium ergonomic laptop cooling stand that provides 6 levels of incline for the perfect viewing or typing angle. A large, 230mm silent fan provides excellent airflow and 4-port USB hub expands device connectivity.
Cooler Master Notepal ERGOSTAND III - notebook stand
Notebook stand
Built-in Devices
4-port USB hub, cooling fan
Fan Diameter
230 mm
Fan Height
16 mm
Fan Bearing
Loop dynamic bearing
Rotation Speed
500-800 rpm
Air Flow
72 cfm
Noise Level
21 dBA
Power Connector
4 pin USB Type A
Rated Voltage
5 V
Manual fan speed control
Product Material
Plastic, metal
38.5 cm x 28 cm x 22.55 cm
1.21 kg
USB powered, adjustable height, removable mesh cover
Notebook stand
Built-in Devices
Product Material
Plastic, metal
38.5 cm
28 cm
22.55 cm
1.21 kg
Heatsink & Fan
Fan Diameter
230 mm
Fan Height
16 mm
Fan Bearing
Rotation Speed
500-800 rpm
Air Flow
72 cfm
Air Pressure
0.26 mm
Noise Level
21 dBA
Power Connector
4 pin USB Type A
Rated Voltage
5 V
Rated Current
0.26 A
Interface Provided
Connector Provided
4 pin USB Type A x 4
MTBF
160,000 hour(s)
IP6X
Scroll to top
