BT.com
Wishlist
CoolerMaster Nepton 240M 274mm x 27mm Radiator w/ Dual 120mm Fans
CoolerMaster Nepton 240M 274mm x...
£98.73
£98.73
Add to wishlist
Delivery
Standard Due date unavailable
The Nepton 240M water cooling system provides a highly effective, quiet solution for those suffering from overheating CPUs. Combining performance driven features such as robust FEP tubing and a larger waterblock skived fin area with noise improvements in the pump and fans deliver a comprehensive all-in-one kit.
Cooler Master Nepton 240M - liquid cooling system radiator
Liquid cooling system radiator
Built-in Devices
Cooling fan
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA2011-3 Socket
Heatsink Material
Copper with aluminium base
Fans Qty
Dual
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
DynaLoop bearing
Rotation Speed
800-2400 rpm
Air Flow
16.5-76 cfm
Noise Level
6.5 - 27 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Product Material
Aluminium, copper
5 years warranty
Built-in Devices
Cooling fan
Product Material
Aluminium, copper
Heatsink & Fan
Compatible With
Heatsink Material
Fans Qty
2
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
DynaLoop bearing
Rotation Speed
800-2400 rpm
Air Flow
16.5-76 cfm
Air Pressure
0.48-4.8 mm
Noise Level
6.5 - 27 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Power Consumption
4.8 W
MTBF
160,000 hour(s)
Limited warranty - 5 years
CoolerMaster Nepton 240M 274mm x 27mm Radiator w/ Dual...
£98.73
Save on this ideal PC Build kit!
Save £8.29
£117.90
Scroll to top
