BT.com
Wishlist
CoolerMaster MasterCase Pro 5 NVIDIA Edition ATX Case
Delivery
Standard Due date unavailable
At heart, the MasterCase 5 advocates a new relationship that binds component makers and users closer together. Its elegantly smooth, flexible FreeForm Modular System supports multiple outlooks, allowing you to upgrade rather than entirely replace your case as your needs change over time. Go with either basic dual top handles and standard door of the MasterCase 5 or an elevated mesh top cover of the MasterCase Pro 5.
Cooler Master MasterCase Pro 5 - nVidia Edition - mid tower - ATX
System cabinet
Mid tower
Metallic dark grey, black interior
I/O Connectors
1 x microphone , 1 x audio line-out , 2 x USB 3.0
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Windowed side panel, top panel dust filter, meshed front panel, front dust filter, detachable top cover, meshed top, supports 240 mm radiator in top, removable HDD cage, bottom dust filter, water cooling ready, supports 120/140 mm radiator in rear, supports 240/280 mm radiator in front panel
No power supply
Specification Compliance
ATX / PS/2
23.5 cm x 51.2 cm x 54.8 cm
10.7 kg
1 year warranty
Mid tower
Max Mainboard Size
ATX
ATX / PS/2
Internal Bays Qty
7
Front Accessible Bays Qty
2
Product Material
Plastic, cold-rolled electrogalvanised SECC steel
Cooling System
Front: 140 mm fan x 2 , Rear: 140 mm fan x 1 , Front: 120/140 mm fan mount x 1 , Top: 120/140 mm fan mount x 2
CPU Cooler Max Height
190 mm
Video Card Max Length
412 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 5 (total) / 5 (free) x internal - 2.5" / 3.5" shared , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
7
1 x microphone - mini-jack , 1 x audio line-out - mini-jack , 2 x USB 3.0
No power supply
23.5 cm
51.2 cm
54.8 cm
10.7 kg
Limited warranty - 1 year
Scroll to top
