BT.com
Wishlist
CoolerMaster MasterCase Pro 3 microATX mini-ITX Case
CoolerMaster MasterCase Pro 3...
£89.35
21 in stock
£89.35
Add to wishlist
Delivery
Standard 1-3 working days
COMPACT MASTERCASE WITH EXTERNAL AND INTERNAL MODULARITY
This new compact addition to the MasterCase line is built with the same FreeForm™ Modular System that defines the series. Customize and adjust your case via swappable aesthetics, adjustable layouts and intuitive thermal performance. Improved layout flexibility handles larger components and cooling systems within a discreet form factor.
FOR MICRO-ATX MOTHERBOARDS
Meant for a smaller build that still packs a punch. Build the high performance PC you want in a tighter frame. Its streamlined design with steel and mesh makes this product incomparably stylish. It supports up to five fans, eight HDDs and two graphics cards.
Compact & PortableSave space and easily transport your build with the MasterCase Pro 3. The reduced size and added top handles mean you don’t have to give your PC the awkward bear hug. Conveniently take your case to LAN parties, special events, and trade shows while still fitting the latest full-sized components
FRONT COOLING BRACKET
Remove the Front Cooling Bracket for convenient fan or radiator installation outside of the case.
REMOVABLE PARTITION PANEL
Remove the Partition Panel to add space for an additional graphics card
SLIDING CLIP & CLICK PANEL
Adjust the Sliding Clip & Click Panel for your needs: HDD cages, DIY cooling system, or remove it
FREEDOM INSIDE AND OUT
The FreeForm™ Modular System allows the MasterCase Pro 3 the same level of customization and upgradeability of the entire MasterCase series. Easily implement all of our MasterAccessories with room for your own customization options, such as DIY liquid cooling
MODULAR DESIGN MEANS FLEXIBILITY
With the MasterCase 3 Pro you have the freedom to build the Micro-ATX PC you want to at a manageable size. There is ample space for up to two full-sized graphics cards, six fans or liquid cooling radiators, and eight HDDs.
Cooler Master MasterCase Pro 3 - mini tower - micro ATX
System cabinet
Mini tower
Black, dark grey metallic
I/O Connectors
2 x USB 3.0 , 1 x audio line-out , 1 x audio line-in
Supported Motherboards
microATX, Mini-ITX
System Cabinet Features
Top panel dust filter, front dust filter, bottom dust filter, supports 120/140/240/280 mm radiator in front panel, supports 120/140 mm radiator in rear, supports 120/140/240 mm radiator in top
No power supply
Specification Compliance
ATX / EPS / PS/2
23.5 cm x 50.5 cm x 46.7 cm
9.1 kg
2 years warranty
Mini tower
Max Mainboard Size
Micro ATX
microATX, Mini-ITX
ATX / EPS / PS/2
Internal Bays Qty
6
Product Material
Plastic, steel
Cooling System
Front: 140 mm fan x 2 / 1200 rpm / 55 cfm / 24 dBA , Front: 140 mm fan mount x 1 , Rear: 140 mm fan x 1 / 1200 rpm / 55 cfm / 24 dBA , Rear: 120/140 mm fan mount x 1 , Top: 120/140 mm fan mount x 2
CPU Cooler Max Height
190 mm
Video Card Max Length
370 mm
Expansion Bays
2 (total) / 2 (free) x internal - 3.5" , 4 (total) / 4 (free) x internal - 2.5"
Expansion Slots
5
2 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack
No power supply
Max Supported Qty
1
23.5 cm
50.5 cm
46.7 cm
9.1 kg
£89.35
Save on this ideal PC Build kit!
Save £8.40
£108.57
Scroll to top
