BT.com
Wishlist
CoolerMaster MasterBox 5t ATX/mATX/mini-ITX Case Black / Red
Delivery
Standard Due date unavailable
The MasterBox 5's design and smartly placed tray cut-outs make light work of installing or expanding multiple interior configurations. Remove, slide and rearrange the internal layout to support larger, high-end components, air and DIY water cooling.
Tray cut-outs also allow for the easy mounting and rearranging of SSDs and HDDs across the motherboard tray, along the bottom shelf, or on the back side of the tray (for SSDs).
Cooler Master MasterBox 5t - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 3.0 , 1 x audio line-in , 1 x audio line-out
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Windowed side panel, fan speed controller, meshed front panel, front dust filter, meshed top, bottom mounted PSU holder, interior painting, supports 120 mm radiator in rear, bottom dust filter, supports 240/280/360 mm radiator in front panel
No power supply
Specification Compliance
ATX
22 cm x 54.12 cm x 51.35 cm
Mid tower
Max Mainboard Size
ATX
ATX
Internal Bays Qty
3
Product Material
Plastic, steel
Cooling System
Front: 120 mm fan x 1 / 3 x 120 mm or 2 x 140 mm fan supported , Rear: 120 mm fan x 1 , Top: 120/140 mm fan mount x 1
CPU Cooler Max Height
167 mm
Video Card Max Length
410 mm
Expansion Bays
1 (total) / 1 (free) x internal - 2.5" , 2 (total) / 2 (free) x internal - 2.5" / 3.5" shared
Expansion Slots
7
2 x USB 3.0 , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack
No power supply
22 cm
54.12 cm
51.35 cm
Scroll to top
